Results 1 to 10 of 178
Thread: 94 Lifted Silverado 6.0/4L80e swap Build
    Jun 2009
    Caledonia, MI
    Need help!!
    Got exhaust ran today! And driving it to the shop I had a few problems (including blowing the water pump).
    Hopefully I can get a few answers for my problems:
    First, when the truck has been driven for a while and is up to temperature, i come to a stop sign and it will want to keep going and if i press the brake to try to stop it it will act like its going to stall out. So I have to put it in neutral. But when its cold i can stop and it will idle just fine with me on the brake.
    Second, I cant get my speedo to work. I have tried hooking nelsons green speedo wire to my Light Blue w/ white stripe wire and nothing happens.
    Third, my RPMS are way off. The tach is reading 1,000 when I am going 55 (using gps). Keep in mind I have 4.56 gears lol so I know that isn't right.
    4th, when trying to confirm the RPMS with a scan tool hooked up to nelsonss obdII port, it says it can not communicate with the ecm. And the check engine light thats on their obd connector is lit up so I know it has power.
    Other than those issues and the water pump, the truck drives like a dream. seems so smooth and takes absolutley no effort for it to take off. pulls really good on the top end for sure. its way stronger than my last cammed out crate motor. Ill get pics of the exhaust job, it looks really good i'd say we did a pretty good job going from the headers to a y merge pipe to a electric cut out to a single in flowmaster to dual out.
    Silverado Z71 10" Lift COMPLETE 6.0/4L80E PRC 2.5 Ported LS6 Heads 228r Comp Cam 3200 CIRCLE D Stall LS7 Lifters ARP Bolts SLP Oil Pump and Double Timing Chain 160 T-Stat 3" SLP Loudmouth Electric Cutout Walbro 255 Pacesetter Longtubes MSD Starter NELSON Harmess NELSON Street/Strip Tuned ECM MSD Wires LS1 Throttle Body Braided Lines Spectre CAI 4.56 Gears Detroit Locker 14 bolt http://www.ls1truck.com/forums/lsx-t...wap-build.html
    don't know how much help i can actually be since you have a 94, but on my 96 i have 2 wires coming from the c100 connector that both said vehicle speed signal, B5 & D4. one is green & the other green w/ white. the speedo wire coming off my nelson harness is green w/ white so i connected to my green/white & no speedo. connected it to the solid green, which is B5 & now my speedo works.
    on the tach mine is doing about the same. it doesn't move till i hit about 3k RPM, then it only reads 1K. i saw myzterray used a 680 ohm resistor. i found 680k ohm & 680 ohm so i'm assuming it's just the 680 ohm. i'm going to hit up radio shack & see if i can get one & what happens.
    i had a friend of mine come over with 2 scan tools. one really nice windows base & it worked fine. he also had a Mac & the Mac wouldn't communicate with it. i rented a code reader/scan tool from autozone this morning & it read just fine. the Mac tool also wouldn't communicate with another friend of mines harness.
    hope you get your problems fixed. to me, all the final small things are harder to solve then getting the motor in everything mounted. all i have left on mine is the tach & all my factory gauges will be working, including the SES light.
    Quote Originally Posted by HPICamaroSS View Post
    Did you wire the brake switch signal to the pcm...? The PCM need a 12 v when the brake are not being applied (the opposite of a standard brake light switch) This signal control the torque converter lockup.
    Sorry for my bad English I'm french!
    Jun 2009
    Caledonia, MI
    Quote Originally Posted by bobbylog View Post
    How do I do that? I'm sure thats the problem because I havent done that lol
    I have never do that to but from what I've read you need a switch like this.
    http://www.ebay.com/itm/TCC-BRAKE-SW...item27c42fbcc4
    http://secure.ultracart.com/catalog/...f/KIT-1002.pdf
    I've read that you can use a relay to but in my case I will just buy the switch.
    Your nelsons harness is supposed to have 1 or 2 wire ready to hook to the switch.
    Edit:
    For automatics with lock up converter, the PCM needs signal when brake pedal is pressed. However, the signal needed is opposite how you're brake lights work. The PCM wants 12v+ constant on this wire when brake IS NOT pressed, and OPEN Circuit when the brake IS pressed. If you vehicle was equipped with a lockup trans to begin with, you probably already have the proper normally closed switch mounted by your brake light switch. If you do not, you can use a relay to perform the same thing. On most relays, there are 5 terminals, 2 of them turn the relay ON when provided ground/power. There are then a normally open leg and a normally closed leg on the relay and a supply. By feeding 12v+ on the supply leg, and hooking the Brake Switch Signal wire to the normally closed leg, you will now have the correct signal for the PCM. When the brake is pressed, 12v+ flows to brake lights, tap into this wire, and run it to the relay to turn the relay on. This will cause the normally closed leg to become open, thus turning OFF the 12v+ signal to the PCM. When you release the brake pedal, the relay will turn OFF, and then feed 12v+ to the PCM.
    From Lt1swap.com http://lt1swap.com/wiringharness.htm
    So you are supposed to already have a brake switch like this.
    Monett Mo
    Its real easy. Just find the brake switch in your truck. Its on the pedal up under the dash a lillte bit. And then look for the purple wire and splice the one from your swap harness to it and your done.
    Jun 2009
    Caledonia, MI
    Quote Originally Posted by 92 6.0 View Post
    Do you know which wire I have to splice it into on Nelsons harness? Because their harness is a 4 wire hookup, and that doesn't include a wire for the brake
    This wire is supposed to be with the dash group speedometer,tach...Also did you wire your park neutral switch? The pcm need to know when you are in gears..
    Sounds like you need a resistor inline with the tach module. There is one year of pcm that has a very weak signal to the tach. Do you know what year your tune is from? Is it dbw?
    Jun 2009
    Caledonia, MI
    I have no idea what year the pcm was but I just sent it back to nelson and they already have a new one for me on the way. They changed the pulse cycle to see if that helps. Once I get it I will let you know. Hopefully its right because if its not then I will have to send it back again, and have them change it back to where it originally was, then try putting that resistor in. I want to say that tune was from a 2002 because I recall them saying those were the easiest to tune. I know it was a 0411 ecm.
