Results 11 to 20 of 21
Thread: No brake/reverse lights
  1. #11
    Sep 2010
    Disassemble and Reassemble.
    That's my vote, you're so good at it, be faster than typing on the forum.
    See you in a couple hours with all problems solved, no need to thank me.
    2007 RC Silverado aka ?
    1998 Trans AM aka Red Dragon
  2. #12
    Hell no
  3. #13
    Broken Bow, OK
    Is the third brake light working?
  4. #14
    idk yet, started raining.
  5. #15
    Jun 2009
    Caledonia, MI
    Did you ever get this figured out? I have the SAME exact problem in my 6.0 swap. No brake lights or reverse, but I have tail lights and blinkers and a third brake light that work.
    Silverado Z71 10" Lift COMPLETE 6.0/4L80E PRC 2.5 Ported LS6 Heads 228r Comp Cam 3200 CIRCLE D Stall LS7 Lifters ARP Bolts SLP Oil Pump and Double Timing Chain 160 T-Stat 3" SLP Loudmouth Electric Cutout Walbro 255 Pacesetter Longtubes MSD Starter NELSON Harmess NELSON Street/Strip Tuned ECM MSD Wires LS1 Throttle Body Braided Lines Spectre CAI 4.56 Gears Detroit Locker 14 bolt http://www.ls1truck.com/forums/lsx-t...wap-build.html
  6. #16
    For some reason its slipping my mind right now and I cant remember when I doo ill post up.
  7. #17
    Sep 2011
    New Orleans, La
    Quote Originally Posted by HPICamaroSS View Post
    I have the exact problem with my '96. Lemme know what you find, please!!!!
    If you're not first, you're last.
  8. #18
    Nov 2009
    SAN ANTONE
    check the 4 connectors under the bed and rear bumper for corrosion they control the rear lights, usually dirt and mud get stuck in them and cause weird shit to happen
  9. #19
    Sep 2011
    Atlanta Ga
    With the swap I'm thinking maybe the Tcc/ brake switch wire.
  10. #20
    Sep 2011
    Mine was doing the same thing. In my case I accidentally cut the wire for the brake lights when I replaced the fuel pump. I just spliced into it under the cab and ran a wire all the way to the block under the back of the truck. Ill fix it correctly next time I have the bed off or drop the tank.
