Results 1 to 10 of 10
Thread: 01 Silverado rear brakes?
    Jan 2006
    Middleburg,FL
    I was wondering if it would be worth it to change my single piston rear brakes to the dual piston?
    Arizona/Utah
    I have the parts sitting ready to go on. I will let you know when they finally go on.
    Jan 2006
    Middleburg,FL
    Thanks
    Aug 2009
    Michigan
    just curious if you would also be using a different proportioning valve? Seems the added clamping force out back may make the rear want to swing around more under extreme braking?
    I personally have just gone to larger rotors, stainless braided lines, and better fluid, and it's made the brakes significantoy better!
    Shralp' it heavy.
    \\ '02 Sierra \V/ '01 Silvy //
    Arizona/Utah
    Easier swap than you might think and some guys claim great results. I am going to measure my stopping distance under several conditions swap rears to 2 piston and fronts to the larger brakes and measure again.
    Aug 2009
    Michigan
    yeah I've heard nothing but good results from people who have swapped to the slightly larger, what is it, 05+? front brakes, but don't hear too much about rears...are those dual piston calipers from suv?
    Shralp' it heavy.
    Arizona/Utah
    Quote Originally Posted by ShredSled View Post
    You are correct sir.
    Jan 2012
    Baytown, Tx
    An update to this tread. I was wondering did you get the rear dual pistons off a suburban or what? Whats all involved with this rear swap?
    Jun 2010
    Ontario Canada home of he Beaver
    Bump same here.
    Aug 2009
    Michigan
    I just read a similar thread on ptnet, and they were discussing NNBS brakes being a direct bolt on to NBS when using calipers and caliper brackets along with rotors... and some were asking if then also Escalade brakes would be a direct swap....
    Shralp' it heavy.
