Well I am fed up with slamming into the bump stops when I have no air in the helper bags. Anyone have a c notch. lmk what you have and how much. Would like to see pics. Pm me or email me zeake13@yahoo.com
Thanks
Jake
Thanks
Jake
are you looking for a bolt in or weld in notch?
Either. The key is price. I can weld it in with no problem and was planning to weld a bolt in for the extra strength. I do tow a 17" enclosed trailer occasionally and every once in a while a 30' travel trailer so I need the strength. Some notches can be had for 69$ but I am a little scared of those.
I forgot to mention my truck is a RCSB 99 model.
as long as they're not too thin of metal & you weld it up good you should be fine with just about any notch. most places sell the notches in pieces
i know mike at dallas hot rod parts sells several different size notches. suicide doors sells a few different sizes also, & Nfamus sells them already welded together & you can cut them down to the size you need.
I have seen a bunch of different ones. I just don't understand why the mcgaughys 33007 is so dam expensive compared to the 69 dollar ones.
yeah, they're really proud of that notch, lol!!! most bolt in notches are more expensive then weld in notch's. that one is also made for the curve/bend in your year truck, where as most weld in notch's are just straight.
I would prefer the mcgaughys 33007 notch if anyone has one used. I can justify used a lot more easily to my wife.
i'll keep an eye open for you.
i think DJM also makes a bolt in notch for your truck.
Djm does have one, just looked it up. About 135 at stylin trucks
Thanks for keeping an eye out. I'd probably go with either of the two.
 Senior Member
						Senior Member
						I have a used set of DJM notches. Dunno what it'd cost to get'm to you tho. They dont weigh a whole bunch.
