Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 32
Thread: Next Modification?
  1. #21
    Quote Originally Posted by cjriojas View Post
    Why would it be better to choose the TC with a different stall speed before he chooses a cam, i thought the tc was matched to the cam?
    I wouldn't exactly say the stall needed to be picked first, but most definitely done first. I think the decision should be a mutual thing though. Pick something out that will work together nicely, then do the stall first.
  2. #22
    Plainfield, IL
    That and 99% of cams require a higher stall. Even a stock cam reacts better with one. Cam/heads are a more important combo in my opinion then cam/stall. Stall should be based on if he tows, percent of highway vs city, etc.
  3. #23
    Mar 2007
    I think you can't go wrong in the 2800-3200 range.
    After that is pure race, and b4 is just playing with yourself !!!
  4. #24
    Feb 2011
    LaPlace, Louisiana
    Its my daily driver and in my town speed limit is 45-55 constant.. I don't tow anything, and if I did I would use the f250..
    Run your motor, not your mouth..
    04 ECSB 5.3 Sierra: 14.6@95
    Pacesetter Headers, Intake, Tune
  5. #25
    Quote Originally Posted by 04SilverBullet View Post
    I'd go with something a little bigger then. 3600 and a 224 or 228
  6. #26
    +1
    Definitely go with at least a 224. Or may as well just find a junkyard 6.0 and let the real fun begin.
  7. #27
    Mar 2007
    Its my daily driver and in my town speed limit is 45-55 constant.. I don't tow anything, and if I did I would use the 2500..
    I corrected that for u !!!!!
  8. #28
    Feb 2011
    LaPlace, Louisiana
    F250 ain't my truck
    The thing is although the speed limit is 45-55, we have about 50 redlights and stop signs here, so I don't want to put too much pressure on the trans. I've been searching around and around for a 6.0.. Can't afford it right now, and would rather start learning a bit by putting stuff on the 5.3..
  9. #29
    Feb 2011
    LaPlace, Louisiana
    I'm getting $425 whenever I'm finished helping my friend do his engine swap.. I've really been considering headers, but I still want a stall.. Like I stated before, I've got 155k miles on the truck, would a converter wreck my transmission or would I be safe? I'm looking into the 3-3200 stall..
  10. #30
    Converter or gears will give you the best ass dyno results. A nice quality unit won't hurt your trans. Or you know, you could spray it.
