F*CK THIS! Got everything all put together, forgot about all this purge bs. Pulled the plug on the relay just to check everything, put my m,ultimeter on, hit the arm switch and it triggers the noids. WTF? Hit my shifter button, cuts the power. F'ing Hurst built a switch, press for off let go for on. F'ing retarded. Busted out the credit card ordered a window switch with and TPS activation.
it was probably designed for a trans brake......should be able to switch em around and itll work
