Results 1 to 10 of 21
Thread: Purge and activation on the same switch.
    F*CK THIS! Got everything all put together, forgot about all this purge bs. Pulled the plug on the relay just to check everything, put my m,ultimeter on, hit the arm switch and it triggers the noids. WTF? Hit my shifter button, cuts the power. F'ing Hurst built a switch, press for off let go for on. F'ing retarded. Busted out the credit card ordered a window switch with and TPS activation.
    it was probably designed for a trans brake......should be able to switch em around and itll work
    I did. I'm just pissed because I went and put and everything back together and loomed and hid all the wires. Now I gotta wait for Nitrous Outlet's forever shipping and then tear it all apart again
    Round Rock, Texas
    Relay networks FTW!
    Plainfield, IL
    hook a horn to the 'noid' relay while testing....make sure it only honks when its supposed to. What I did. Good safety measure.
    I just unplug it and plug my multimeter in and prop it up on the windshield..
    Round Rock, Texas
    Or wire it correctly the first time.
