Results 1 to 10 of 20
Thread: aluminum 5.3 block???
    Broken Bow, OK
    Quote Originally Posted by IXLR8 View Post
    Aluminum also dissipates heat faster. So an all aluminum motor will run a bit cooler.
    That may be true, but it will still run at the same temp that is determined by the thermostat.
    Apr 2010
    I might be wrong but Im pretty sure the alum. 5.3s have iron sleeves. so boring might be possible if this is the case..
    -Custom Catback with Cherry Bomb Extreme,L33 with 799s, Pacesetter Headers, Electric Fan, SHIFT Technologies Shift Kit, Corvette Servo, 3 inch lift, 18" Factory Infiniti FX Wheels, 285/65/18 Nitto Trail Grapplers, 6000K HID fog lights, 8000K HID low beams, Wheatley Tuned.
    Jun 2009
    Washington DC
    Quote Originally Posted by kyle.p12 View Post
    It definitely has iron sleeves, almost all aluminum engines do. The point was that you can't do a real heavy overbore on these 5.3's because there isn't enough sleeve material to maintain wall thickness. Not as bad as an LS1 (which can basically only tolerate a hone), but just not worth the hassle imo
    Jun 2010
    I think you missed my point. An aluminum motor radiates heat better than a cast iron motor. It's like adding more cooling capacity, and will usually allow a tiny bit more timing and compression.
    Broken Bow, OK
    I know exactly what you are saying, but the cooling system is what determines operating temperature, not heat radiation from the block. It might cool slightly faster after shut down, but while the engine is running it won't affect it. If both engines have the same thermostat and cooling system, they will both run at the same temp.
    Jun 2010
    You're still missing the point. The heat transfers better which means fewer hot spots. This faster more uniform heat transfer is the reason you can usually run a tiny bit more compression and/or timing. It doesn't really have anything to do with the thermostat. Do you think the thermostat has total control of all the temperatures inside the motor? It doesn't. It just regulates the water temp.
    If you've ever tried to weld aluminum you'd understand. The heat transfers more uniformly through the aluminum part which makes it more difficult to weld. If you aren't careful the whole part will melt. Instead of having a small easy to control weld puddle (as you do with steel), the whole aluminum part can melt and fall out because the heat transfers through the whole part faster than it does with steel. This is a perfect example of why you have fewer hot spots in an aluminum motor.
    It also means the radiator doesn't have to work as hard to keep the motor cool. If you had a marginal cooling system on a very hot day, an aluminum motor would help keep the temperature under control.
    This superior heat transfer also means that an aluminum head will make slightly less power than an equal cast iron head. But you can usually make up that difference with a little more compression and/or timing.
    Nov 2009
    chicago, il
    You can argue the benefits of aluminum versus iron untill the cows come home. I don't own cows, so I will not participate. As the thread starter stated, the engine in question is free. This should make the decision a piece of cake, take it! Put ported truck heads on it, and stick a 220 cam on a 114 in it. I think you'll like the outcome.
    Apr 2010
    Quote Originally Posted by truckinL33 View Post
    I agree!! and even though it doesn't have the sweet heads like the L33, itd still be fun to build and maybe make some money on!!
