Results 1 to 5 of 5
Thread: 5.3 apps problems
    Mar 2012
    5.3 apps problems
    Hi all, new to the forum, I have just fitted a 2003 5.3 to a 52 chevy pickup. All went well and it is up and running but I have no throttle. When I got the engine I didn't get the loom from the pedal to the TAC. I connected it as per some info I found on line but no go. The pedal has 10 pins. In the info I have it says the 5volt supplies from the TAC are pins G,D and E, I have 5 volts from pins B,K and G. Does anyone have any info on which pin connects to which, I have tried to buy the loom but I have had no luck, I live in NewZealand and some things are a little hard to get. Thanks for any input.
    if you dont finds an answer some of us that have access to parts can look around for you, i wouldnt think it would cost you all that much to just buy one and have it shipped, as long as someone picked it up from a scrap yard or something.
    Mar 2012
    Thumbs up
    OK thanks, I might take you up on that.
    Jan 2012
    warwick ny
    Give Just Chevy Trucks a call they deal with these swaps all the time and the have lots of parts. 207 457 5500
    Jun 2011
    Sioux Lookout, Ontario
    Don't forget to ground the tac module itself, or it won't work.
