Originally Posted by
JRodsGarage
Ive seen most of the guys in the TBSS run a 3000 stall converter with this cam. Most likely what I will use, as it has been a popular choice. So, what you are saying is to keep the rear gears as they are(I still need to find out which) and adjust as needed? Sounds like what I was thinking as well
2 different vechicles, if you ask me a tt3000 stall is for towing purposes,you said you wanted a weekend warrior and something you can bring to show, this to me means its not gonna be driven much on the streets maybe occassionally, thats fine i drive mine with a 4800 stall triple disc, im saying this is ideal but it'll give you a idea how much can be tolerated on the street, hint: 4k stall, but lets leave the stall out, this is how i would approach the whole thing, get the motor together and the truck running, if it is then great, get to a dyno do a few pulls and see where the peak power is, once you do this then you can decide what stall is gonna in the best interest to launch the truck
which rear end you running now the stock one?
Simple: 408 on steroids!
single digits coming soon!
