Results 1 to 10 of 12
Thread: Head Work
    Head Work
    I have some 799 heads I plan to use on my 5.3, but I dont know what to do to them. I was thinking milled .40 and 3 angle job, along with bigger valves. Any suggestions, or advice would help. Currently truck has 212/218 cam, tb stall, headers, 3" full exhaust, ud pulley, tbss 90mm intake, volant air intake and nitrous. I want to use the heads with this setup first, then i'll eventually get a cam and stall to match the heads.
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    Quote Originally Posted by graysilverado5.3 View Post
    have you thought about what your CR would be with the milling of the heads at .40 ?
    get them ported by a pro, WCCH ports heads i would talk to someone that has a good rep on porting!! setup sounds nice or will be once done... when you decide on cam get it spec'd ... it should run very well
    Simple: 408 on steroids!
    single digits coming soon!
    Im not too sure on the CR, but I believe milling the heads .30 brings up the compression to about stock, more or less. So milling .40 should increase the CR more than whats stock.
    now are you talking .30 mm or .030"? Use your decimals properly or its very confusing. .30(mm) would only be about .012".
    Sorry,i meant .040, wasnt to sure on the decimals.
    Round Rock, TX
    I have a guy thats puts most of the BIG name places to shame on head work... Last set dyno'd 32rwhp/27ftlbs on port work alone. They did not get milled for a compression increase. Its a stock bottom end LS1 with 243 heads and a ms4 cam. 438/391 before and 470/418 after. Same dyno and weather.
    Quote Originally Posted by DBRODS View Post
    Wow, can you send me a pm with his info.?
    Feb 2010
    Central Texas
    So he had heads done and did a cam swap or it had the same cam on tha first run.
    Round Rock, TX
    same cam... Only had headwork done.. Nothing else changed..
    Elsa RGV & San Antonio TEJAS
    always good to know along with prices to compare....i am sure he beats some of them names too???
