You know they are doing a LSX Motor shootoff...
GM Performance Parts | Black LS7 Camaro
I wish i could go to that!!
I wanted to go to that so bad but the truck won't be finished and I am kinda low on funds(imagine that)
maybe this will be a yearly thing,
Mark
http://www.denalitrucks.com/sm-files/mark-sig.jpg
But Officer, I swear its just a vacuum leak.
Those red things? those are smog pumps!
2004 Sierra Denali ----- 2/4 drop
LSX 438 TWIN TURBO
LSX Block Video
Block number 00370. Build Date 04/17/2007
Took a few more pictures today, Slowly it is coming together.
LSX 438 TWIN TURBO
LSX Block Video
Oh yeah, now that's what I was talking about.![]()
that is one badass setup dude ,you must have a ton in that setup .i didnt read every thing on it but i could imagine some high iats on it what are you using too keep it cool ,ive got a single charger and ive been through hell just getting iats were i want them.2 turbos i would think produce alot of heat i would think .just curious ,havent followed it all the way through.i did see 1 intercooler doesnt seem enough ,for street.let me know.
Hot pipes will be coated, Turbos with have a blanket and the intercooler will work great. I will be running a ton of Meth for both cooling and octane boost. I bet I won't see AIT more than 20* above ambient.
Mark
LSX 438 TWIN TURBO
LSX Block Video
I thought I would back up a littl and show you some before pictures.
LSX 438 TWIN TURBO
LSX Block Video
Why are you running a MAF with that setup?
Gone, but not forgotten!
LSX 438 TWIN TURBO
LSX Block Video
