Results 1 to 10 of 18
Thread: lsx swap in 95 obs close to being finished
    Aug 2013
    I started the swap a while back and finished it 2 months but still have a little tweaking to do. Need help on a/c lines already fabbed up a bracket for under 30$ need tach. To work oil pressure not reading and water temp. Found a temporary fix for temp. And rpms. I'm using a Bluetooth obd2 adapter from eBay with a phone app called "tourqe"
    *built 4l60e vette servo, tbss stall, and custom shift kit
    Looks good.. do you have any pics of the whole truck?
    Aug 2013
    There is a couple of pics when I first got my truck and now not too much done
    Jan 2014
    Google "obs Ls swap temp gauge" and click videos. There's a video of a 98 camaro 3 wire temp sender one wire to the gauge, other two to the pcm.
    As for the oil gauge, you should have left your original sender and used an adapter.
    The tach is the white wire running from the conectrr driver side below brake booster, you may need a resistor for it. Check out lt1swap.com he shows how to wire it under 99+ lsx tach wiring.
    Aug 2011
    Ellsworth Air Force Base, SD
    For the oil, you can remove the 2 bolt cover port next to the oil filter and tap it. There is a dummy hole on this cover, just drill and tap through that.
    1994 Chevy C1500 RCSB 05' DBW 5.3 Conversion Complete
    My build
    Coming soon ....... Full Repaint, 214/220 Cam, Yukon Posi with 3.73's, remove body lift
    Sep 2012
    Quakertown, Pa.
    Here's a neat trick for the temp guage sender. If I had found this info sooner, I would have went this route instead of doing what I did.
    http://www.impalassforum.com/vBullet....php?p=2667060
    John
    Aug 2013
    Thanks everyone but this is the route I decided to go with for the water temp I just need to go to gm and order the lt1 firbird temp sensor with the 3 wire setup and should fit fine
    http://m.youtube.com/watch?v=1Ew1YSm8jd0
    now for the oil I actually want to usethe adapter to my original sender from S/P but they have a lot of diffrent sizes and I don't want to order the wrong one
    Aug 2013
    The build is a budget build just thought id mention that due to money being tied up for school
    Aug 2011
    Before you commit to the 3 wire you might want to read this, it was in the stickies.
    http://www.ls1truck.com/forums/showt...219#post432219
    My build
    Jan 2012
    warwick ny
    Quote Originally Posted by Bear View Post
    I put that 3 wire sensor in my 1992 chevy pickup and the gauge reads perfect.
