Results 1 to 9 of 9
Thread: fuel pump swap
    Feb 2011
    Sevierville, TN
    fuel pump swap
    The fuel pump in my dad's 01 Silvy is bad and needs to be changed. Is it easier to drop the tank or remove the bed to change it? How hard is it to remove the bed?
    Matt
    Thanks to all American soldiers for their service and sacrifices.
    Jan 2012
    DFW, TEXAS
    i would remove the bed. 8-18mm bolts, unplugg the taillight harness, and 3-7mm (fuel filler). unless u have a lift.
    Lift bed
    Jan 2012
    Baytown, Tx
    It was recommended to loosen the pass side bolts do not remove them. Then remove the drivers bed bolts and jack it up from the frame rails. When I get home I will post link up from pt.net where they posted pics on how to do it.
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
    1967 Chevy II 5.3 w/ 76mm snail
    Two guys can lift the bed off rather easily. I don't like jacking up one side.
    Feb 2011
    Sevierville, TN
    We don't have a lift, so it looks like we will be lifting the bed off of it. Thanks for the advice, guys. N/ALS1, that link would be a big help if you can find it.
    Matt
    Or, pull the rear wheels off, unbolt the bed and just slide it back.
    Jan 2012
    Baytown, Tx
    Ill get it for sure tonight. I was busy with my 9 wk old last night.
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
    Jan 2012
    Baytown, Tx
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
