Results 1 to 10 of 14
Thread: Another HELP! Different issue different truck
    Jul 2009
    Oklahoma City
    ok so on my 81, i put in the 2002 5.3 4l60 in it. at first i ran a walbro 255 inline pump. it couldnt keep up. so i put in a aeromtoive intank pump. worked great for about 6 months. then it just randomly died. then it started up but acted like it couldnt keep up. so i changed the fuel pump again to an ac delco pump. worked great last night when i test drove it for about 8-9 miles. im like good deal it works. so i drive it to work today. works great till the last mile or so then it starts acting like theres no fuel. and it only when u give it gas in gear. at idle its fine and in park and give it gas its fine. im tired of changing pumps and im tired of not being able to drive it. its not throwing a check engine light. i dont know if maybe its a sensor going bad or a connector is loose somewhere but i would thing it would throw a code. i cleaned the ground on the frame for the pump and re ran a whole new power wire for the pump. also i dont know if it has anything to do with it but sometimes randomly the fuel gauge will read full or empty when its not full or empty then it will catch up i guess you could say to what it really is then go back to either full or empty like its getting a mis reading or bad ground. kinda like when you unplug the oil pressure sensor and the gauge goes to the max. help would be greatly appreciated.
    btw im running rubber fuel hos to and from the tank. a friend used the same stuff and his truck is fine.
    Jan 2012
    warwick ny
    How is your hose in the tank attached to your fuel pump?I had mine come loose and my fuel pressure dropped to 20 psi.What fuel pressure do you have at the rail?If you are runnig the corvette filter maybe that is going bad.If you can check pressure at rail first to see what you have.Mine would idle and run fine at 20 psi but if i floored it it would break up after 4000 rpms.
    Jul 2009
    Oklahoma City
    Hose clamps on the connection. Its not loose. At the rail last time I checked at idle was around 45-50 but my gauge had a leak and I haven't bought a new one. And the hose isn't long enough to check while driving. I dont have the corvette filter. Im running a return style fuel rail so I have a hose coming from the rail all the back back to the tank. And mine starts cutting out way before 4000 rpm when it's in gear.
    crazy question for ya. Have you changed your fuel filter? Any of the three pumps you listed should support a 5.3. If your getting that high of fuel pressure at the rail you should be fine. I think gagliano was meaning the little fuel line between the fuel pump and the assembly. Did you get some good high pressure fuel line? Its only about 3 inches long. Also make sure you use some good hose clamps so it wont blow off. Did you run a new power wire to your fuel pump? May want to do that and clean up all the connections.
    91 RCSB-- Forged LS7 bottom end, ported LS3 heads, ported LS3 intake, custom EPS cam and a 4l80e.
    Jul 2009
    Oklahoma City
    Yes the fuel filter is new in the tank and a new summit filter. Im running rubber fuel hose from oreillys. And I have two clamps on the pressure and return lines at the motor and just one on each at the tank. My lines have never come off. What's this 3 inches long hide yr talking about? Also I have run a new power wire and cleaned up my ground wire.
    Jan 2012
    warwick ny
    The 3 in line i am talking about is on the sending unit inside the tank.What are you using for a regulator?Maybe that doesn't hold the right pressure under a load.
