Results 1 to 5 of 5
Thread: Bump steer 3/4 drop
    Bump steer 3/4 drop
    Have really bad bump steer on 3/4 drop using spindles and springs up front. Everything is new tie rods, ball joints, bushings, etc. What can be done to fix this? Heard about a kit to turn tie rods upside down? Steering stabilizer?
    Has it been aligned?
    Yes.
    Aug 2009
    Fort Riley, KS
    DJM sells the kit. You drill out the spindle and put in a tapered insert, this way you can flip the insert over and go back to stock. Just need to make sure wheels will clear.
    04' RCSB, LQ9, Front mount T76, TU1, Circle D 3K, Built 4L60E, True Trac, 3.42:1, 4-6 Drop
    Thanks! I will give it a try
