Results 1 to 9 of 9
Thread: Door locks
    Aug 2010
    Door locks
    Anyone ever had trouble with door locks. I have a 2008 Silverado with 17,000 miles on it and the left front door doesn't unlock. Any idea's?
    Old member, going to be more active on here.
    Jun 2009
    Washington DC
    the power lock module or the key lock itself?
    Aug 2010
    The left door lock seem's to be sticky inside the door itself. Doesn't respond to remote all the time or unlock itself when put into park.
    Quote Originally Posted by jonm38 View Post
    Aug 2010
    I do have a recall on it. Will be going in this week.
    Jun 2009
    Washington DC
    Definitely sounds like a bad lock module or bent linkage. Did you ever lock yourself out of the truck and get a locksmith to let you in? Some of those guys are heavy handed when manipulating the linkage assembly inside the door. If the linkage gets bent out of shape in any way, it can put a strain on the module, causing it to work harder than it was designed
    Feb 2012
    Mcalester ok
    My 08 has window switch probs
    Oct 2011
    San Antonio TX
    Ha suckerz nothing beats manual locks n windows
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Oct 2010
    Pearl,MS
    ^^ spam
    2005 CCSB Silverado- 5.3
    Airaid CAI
    True Dual Exhaust
    NPTune
    3.73 Yukon Duragrip limited Slip Diff.
    Jun 2009
    Washington DC
    yep
