Results 1 to 8 of 8
Thread: Looking To Cam+Stall 5.3 Tahoe, Need Suggestions
    Feb 2012
    New Jersey
    Looking to get some more power out of my 5.3 and have been thinking of a cam swap and replacing the stall converter. Current mods are in sig.
    Anyone know what size cam I should get? I have been looking at a 224/228 cam from texas speed but not sure if it would be the best option. Trying to get as much power as I can for a daily driver.
    Also not sure what stall converter to get. I have been looking at the converters on performabuilt.com. They offer OEM style, 9.5 inch, and 10.5 inch. Not really sure what the differences are, but I was looking for around 3000-3200 stall and it said that the OEM ones only go up to 2500 stall but the 9.5 and 10.5 range from 2800-5000. Could anyone tell me the advantages of the bigger sized converters?
    http://img543.imageshack.us/img543/7362/100mediaimag02751.jpg
    2003 Tahoe LT 22" KMC SLIDES, DJM Cornering Kit, LT Headers, Corsa Sport, BB 93 Octane Tune, E-Fans, Performabuilt LVL 2 4L60E, CD 3400 Stall 258mm, TR224 Cam, P-1sc procharger
    12.503 @ 105.49
    Arizona/Utah
    That cam would go great with a 32-3400 stall from circled give them a call and describe your build and goals and they will set you up perfectly.
    Mar 2010
    San Antonio, Tx
    Usually the smaller the diameter converter the better torque multiplication. For yours I would do a 10", a 9.5" might be too small for the weight you have. I would go 34-3600 stall. Also, if you lost those 22's you would gain almost as much as doing just the cam
    2002 ECSB 2WD 5.3
    1995 Formula Firebird 383 LT1
    1984 Camaro 408 SBC
    Most sports require one ball, motocross requires two.
    Racing isn't a matter of life and death, it's much more important than that.
    Feb 2012
    New Jersey
    Thanks, I have been looking at the Performabuilt ones because I also planned on getting a level 2 4l60E from them and if you buy one of there converters, then they extend your warranty from 1 to 2 years. Not sure on there quality though and I might end up with a Circle D or a Yank
    Quote Originally Posted by screaminchicken View Post
    Lol yea I do need to lose the 22's, but I love how they look too much. I do go back to stock for the winter though.
    Do you think I need that big of a stall? I am from tahoeyukonforum.com, and everyone seems to use between 2800-3200 at most for their stalls.
    12.503 @ 105.49
    Arizona/Utah
    Quote Originally Posted by Phantomx55 View Post
    generally speaking on this site we are very performance oriented and have a tendency to recommend bigger and wilder stuff and not so much mild junk. A 2800-3200 is great for a 220-224 cam in a 5.3, but above that it's a lot more fun to have more stall. A 226/230 .6xx/.6xx cam with a 3600 triple disk from circle d would make for an awesome build. It would scream, but still be a DD friendly setup.
    If you want a real accurate suggestion for a stall speed go to www.circledspecialties.com and ask Chris. Circle D is a site sponsor and makes an awesome converter.
