ok im almost ready to do the swap.. got all the part but a few.. but what i need to know is my truck has ABS that the PCM controls.. i have a stand alone harness and new PCM.. what do i need to do with the ABS? can i pull the old PCM out and all the wiring and just leave the stuff to run my gauges..?
also i plan to leave the stock 5speed in the truck NV3500 i think.. but what to run a aftermarket flywheel.. billet aluminum flywheel.. what year will work? i know the stock 99 4.8 will work but is there a aftermarket one thats the same as the 4.8? i called summit and the guy was lost... i called ram same thing...
if i go with the stock flywheel will my stock hyd throw out bearing work.. also with the stock 96 truck clutch work on the 4.8 flywheel?
sorry so long winded this are the few things thats holding me up...
