Results 1 to 7 of 7
Thread: trans from blazer fit into truck?
    Jan 2011
    well i just purchased a 99 1500 4x4 with 128k miles. pretty stoked about it. i bought it will a trashed transmission. i consider the truck to be pretty rare. its an ext cab short bed 4x4 with a 4.8/auto. has all power interior thats cloth. but the 4x4 lever is in the floor not push button. i have a transmission out of a 1999 chevy blazer its 4x4 i know its good. the only thing is, it has a push button 4x4 t case. can i swap this trans into this truck without any problems? they are both 1999 4l60e's the blazer had a 4.3 and i have a 4.8. will it swap right in and will my t-case go in? its only temporary as i dont have the money to swap a 80e in right now. thanks in advance!
    97 s10 for beater
    99 nbs ext cab 4x4 4.8 performabuilt level 2, 3.73s
    lq4 sitting in the garage...
    Oct 2009
    huntington indiana
    i think a 60e is a 60e, you might have to swap out bells and tails. are you wanting to swap t cases? if so good luck with the wiring, i would give that idea up. i would check a dealer or shop b4 i got started and dont use the 4.3 tq converter on the 4.8
    procharger p1sc, nelson tune, 42# marine injectors, walbro 255, lt's, ory, 4" volant cat back, PerformaBuilt level 2 pro race trans, trans. cooler with e fan, 2500 stall, aem wideband, energy bushings, spohn perf. trailing and panhard rods, mb & gear alloy 22's ( ya 2 sets, im big ballin), ss brake lines, drilled & slotted rotors, bla bla bla bla bla bla bla,
    and ya it will beat a hemi.
    Was the blazer fullsize version or are you talking trailblazer. The bell housing will bolt to the LS based engine with one bolt hole missing. You will need to get the flat style flex plate, longer crankshaft bolts and flywheel spacer in order to use the old style trans in the LS engine. CrateEngineDepot.com has the flexplate assembly for a very reasonable price. I will bet money the v6 4L60 trans will die a quick death behind the LS engine.
    Jan 2011
    i asked if my t/case will bolt up fine to the blazer trans. and its a 99 s10 blazer...only blazer chevy made at that time.
    97 s10 for beater
    Quote Originally Posted by boosted View Post
    You asked transmission right here.
    You want to put the 4.3L Blazer trans and transfer case into the C1500? Why not just put just the transmission in with a flat flex plate and call it good then you won't have to do any conversions.
    Jan 2011
    in the first post i said the 99 silvy is 4x4. and in the quote u just posted of me says "will it swap in and my t case go in" i was in a hurry when i posted and meants will MY transfer case bolt up to the blazer trans
    97 s10 for beater
    Plainfield, IL
    I BELIEVE the bell housings AND tailshafts are different on the s10's vs fullsizes. You could have both swapped over from fullsize to s10 trans...but the tailshaft involves pulling it all apart. Honestly, I would try to sell the s10 trans, and just pick up a fullsize trans from the boneyard if you can't afford a rebuild.
