Results 1 to 10 of 11
Thread: cam question
    cam question
    Hello, I would like to know what you guy's would suggest for a cam for me. I have a bone stock 6.0 LQ4 with 31K on it, and 317 heads. The engine is in a crew cab stepside 95 chevy, so it's heavy and I am not expecting a rocket, just good power to pull the truck around. I don't want to change my torque convertor in my 4L60E, and I am running 3.42 gears, I also don't want to change heads, but I know I will probably need to change valve springs, I would a nice choppy idle, but without loosing all lowend torque. Mainly I want the cam for the sound at idle for cruising around at shows which is where this truck will see most of it's time. Thanks for your input.
    I have been searching and I really like the sound of the TR224 cam, what would need to be changed to run this cam? Thanks
    wichita falls, tx
    cam, valve springs, and gaskets
    Intro Radicalli's
    Mar 2007
    Newark, Delaware
    Quote Originally Posted by banker099 View Post
    X2, you could also throw in some hardened push rods. The TR224 should work well for what you want.
    May 2010
    el paso, tx
    Quote Originally Posted by Beatdown Z View Post
    beatdown, did you drive your truck with the cam before putting in your yank? i dont think i would do a tr224 without upgrading the stall. but i wouldnt know for sure as i did my stall before i did my cam
    06ccsb, cammed, stalled, geared
    Mar 2007
    Newark, Delaware
    Quote Originally Posted by 06Sierra2 View Post
    No, I swapped everything at once. Do you have a 6.0? Just judging by the way my truck can pull on hills at 1200 rpm, makes me think that it didn't lose too much lowend torque over the stock cam. Even with the stock stall and TR224, I'm guessing lowend power would be equivalent to a 5.3 stock cam/stall...
