Results 1 to 9 of 9
Thread: LQ4 with 862 cam suggestions
    Dec 2008
    La Porte TX
    I am not the brightest when it comes to knowing the biggest or the better to go with nitrous. I will be using a stock block to start with my 862 heads, 7.4 pushrods and will purchase the double springs for a good lift. Just not sure if the biggest is the best for nitrous nor whats the biggest lift possible for this combo. Any help would be appreciated.
    5.3, small cam, 918 springs, 7.4 rods, walboro pump, Full built 4l60, 2800-3000 stall, TB spacer, long tubes, cat delete, single 3" exhaust with Aero bullit muffler. Flaco tuned.
    Mar 2007
    Newark, Delaware
    Why 862's? Are they ported? Just pick the best N/A cam for your setup. You don't have to worry about nitrous cams until you're spraying big shots. I would get a 228 cam, like this one on ebay: http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
    Dec 2008
    La Porte TX
    Well i was even thinking of the majic stick.
    Mar 2007
    Newark, Delaware
    You could, but you don't have good heads or stall to compliment it. For the MS3/4, I suggest you get at least 243's with a valve job and a 3600 stall.
    Dec 2008
    La Porte TX
    The stall will be changed Before it drives for sure.
    Dec 2008
    La Porte TX
    I will look at getting some of those heads. I thought the 862's would be great for the compression.
