Thread: how do you check to see if the STS oil pump is on hi or lo speed????
    Oct 2009
    Katy ,Texas
    well im having issues with my brand new turbo thats only 1 month old, it always has oil on the lower part of the compressor housing. i was wondering how do you make sure the STS oil pump is on hi or low speed? right now i just have the positive to positive and the negative to negative. i do not have the pressure switch hooked up but its there, because i didnt get the harness for the buzzer system.
    06 silverado crew cab 4.8L
    STS Kit W/turbonetics BB 60-1 .81AR T4 and intercooler 10psi
    Nelson custom tune
    built 4L60E-hopefully it lasts
    2500 stall-Hughes converters
    42LB injectors
    3.5 Magnaflow exhuast
    6inch lift on 35x12.50s
    here is some stuff I found on the STS oil pump on pt.net
    http://www.ls1tech.com/affiliates/tr...d.php?t=437911
    Oct 2009
    Katy ,Texas
    thats all very good information thanks , but i do not have the harness for the buzzer or the crankcase pressure switches or anything, just vented crankcase to atmosphere and have the main harness with only a positive and negative wire running to the oil pump . the pump is tapped in to the fuel pump so i really dont know what speed its on?
    Nelson custom tune
    42LB injectors
