Page 1 of 18 1 2 3 11 ... LastLast
Results 1 to 10 of 630
Thread: Gears, Posi's, Lockers, Bearings, Axles, More!
    Sep 2009
    MI
    At Rons Machining Service we offer a full line of rearend parts and components at very competitive prices. Everyone is welcome to ask technical questions, price quotes, or anything else that may be on your mind. Here is a small sample of what we have to offer:
    GM 8.5 & 8.6 (10 bolt)
    Gears: $119.00 (most ratios)
    Detroit Truetrac: $425.00
    Eaton posi: $395.00
    Detroit locker: $598.00
    Master install kit: $80.00
    Axle bearings & seals: $60.00/pair
    Complete gear/posi/install pkg's: from $575.00
    GM 9.5 (14 bolt)
    Gears: $179.99 (most ratios)
    Detroit Truetrac: $495.00
    Eaton posi: $425.00
    Detroit locker: $615.00
    Master install kit: $139.99
    Axle bearings & seals: $75.00/pair
    Website: RONS MACHINING SERVICE Home Page
    E-mail: rmsdrivetrain@hotmail.com
    Phone: 1-800-694-3098
    Ill be ordering a tru trac soon as i was screwed over on one that had been machined down to fit pre 98 stock bearings
    5.3l-Tsp 220/220 .581/.581 112LSA, Comp 918 revised springs, tsp pushrods-UDP intake, LS1 E-fans, Walbro 255,vette servo, tru cool 40k cooler-4.11s with detroit tru trac. Nitrous Outlet big noid wet system with Harris Speed Works plate and Microedge controller-only on 75 shot........for now!
    hey ron,i ordered the 4.11 gears for 119.00 for 08'silverado,in a green/white box,,i noticed yall offered a set for 225.00.
    will i be ok with these that i have?
    would i be able to reuse all my seals/bearings?truck only has 8k miles.
    also ill be getting the tru trac as well...
    thanks for the fast service
    Sep 2009
    MI
    Quote Originally Posted by STUNNA View Post
    Hello, yes the gears in the green and white box are USA Standard gears. I believe you will be happy with these, they are our hottest selling gears. You can reuse the original parts except the crush collar. A new crush collar should always be used when changing gears. We have the Truetrac for $385.00. Thanks for your business!
    Sep 2009
    MI
    Thanks for all the great comments guys!
    Sep 2009
    MI
    Thanks for the order David!
    boy you repeat yourself alot Ron lol
    take time to read the first page fellas
    Detroit Truetrac: $385.00
    Eaton posi: $395.00
    Complete gear/posi/install pkg's: from $520.00
    GM 9.5 (14 bolt)
    Detroit Truetrac: $449.99
    Eaton posi: $425.00
    Ron i should be calling you this coming monday gotta friend needing some gears and carrier
    thanks for all you've done for me
    Simple: 408 on steroids!
    single digits coming soon!
    midlothian, Texas
    these are great folks!!! I ordered my install kit from these guys years ago and they were always very helpfull! great prices too!
    06' rcsb silverado H/C/I/N2O 5.3
    Dec 2009
    Corona, CA
    Hey Ron
    How much for a detroit locker, gears and install package for a 75 blazer?
    i believe it has a 10 bolt 8.5 rear and maybe a 44 front?
    Thanks,
    Chris
    2007 GMT900 CCSB 5.3 VTS2300 Twin Screw Supercharger, Doug Thorley LT's, True 3" Duals into Dynomax Race Bullets, Nelson Tune, 4L80e w/transgo HD2-D, Truetrac, 4.10 r&p
    Need list: Stall, PLX 200 for my crappy AFR, X-pipe, GM 20's.
    ron closed till 21st?
