Results 1 to 10 of 19
Thread: Infinity Speakers-2 ohm
    Will I have any problems using Infinity speakers with my stock HU? The 4x6 plate in the rear says 9.5 ohm. The Infinity is a 2 ohm. Any problems?
    95 SILVERADO EXT.CAB-5.7-175,000 AND STILL GOING-LOOKING FOR 5.3 SWAP
    S.A. Texas
    I just put in some polk audio in the front on my stocker adn it sounds really good.
    May 2004
    Quote Originally Posted by 95WIP View Post
    The Infinity Kappa plates are weak! Should be fine with a stock head unit and no amp. I just pulled out my 3rd set and will be moving on to something better.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    I'm putting in 6X8 Kappa 682.9 2 way in place of the 4x6. I had a previous post about the install. Now, The speakers will play fine for a while, then stop playing. They will not resume playing until I remove the passenger side rear speaker. Then, I can reinstall it and they will play again. I think I have a ground issue, but not sure. Any way to tell?
    Augusta, Ks
    Sounds like you are pulling to many ohms from your head unit.
    2004 Buell XB12s
    Any way to check if this is the problem?
    Augusta, Ks
    You said the infinitys are 2 ohm and your factory ones are 9.5?
    2004 Buell XB12s
