Building an '06 sierra 2500, its a junkyard refugee(I work at a salvage yard).The body, ecm, bcm, speedo, column, and dash harness are off the '06 sierra. The motor, the associated sensors, and the engine harness are off an '06 Silverado. All the plugs and fuse panel were the same, so I know that's not the problem. I've got the truck together enough to try to start it. The first time I hit the key, it started and ran for about 2 seconds and shut off. When I tried cranking after that, it makes the fuh-fuh-fuh sound(technical term) like it wants to start, but doesn't. I've got good pressure at the fuel rail, and the fuel pump is running. There isn't a security light on, so I don't think its the security. One thing is the motor has been sitting for 5 years, is it possible the injectors are stuck shut? is there some kind of re-learn I need to go through? any thing else I might be missing? The motor spins nice and is clean as a whistle inside. Also, plugs are clean and dry...seems to point to lack of fuel???
