Results 1 to 10 of 18
Thread: Wtb 9.5" 14 bolt 6 lug
    Oct 2007
    Looking for rear axle assembly to do the 14 bolt swap. Gear ratio doesn't matter but need it to be 2006 up rear end.
    Mar 2007
    Quote Originally Posted by Tarinitup1 View Post
    that dude on Nelson Performance....Allen I think got mine fully built
    Gives those guys a call. Maybe they can help u.
    Get with whiteout ( Israel)
    Oct 2009
    Odessa, TX
    Why 06+?
    99 GMC - RCSB 408 w/98mm whistle... WSLS Racing...
    Pittsburgh, PA
    FYI the 05-06 rear is hard to come by replacement parts as in axles. I snapped an axle and had to go thru GM to get one and it was 305 for a single one. I tried Moser and they didnt have any stock that large. SUperior doesnt make any nor do others
    If i was to do it again, id go 9"
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Oct 2007
    I hear ya but don't have the coin for a 9". Might even have to build the 10 bolt if I can't find one or it's too much. What's good price for used one?
    Pittsburgh, PA
    if you resort to using a 14bolt use one from a GMT400 truck. axles are more available. just have someone move the perches
    i paid 1400 for mine back in 06 had 1k miles on it
    Find a 9" from a junk yard for 50-100 bucks. then upgrade the parts. You might get lucky and find a fullsize ford that has similar width as your truck. this might be best route, you can also get a backbone brace cheap as well. If you can weld youre golden. Its possible you could have less then 1000 into it. [depending on how you go about this]
    412 Motorsports
    Round Rock, TX
    Dutchman makes replacement axles for the 14bolts.. Been running some in the TBSS for a while now.. Good parts
    Pittsburgh, PA
    do they have them for the truck ones thou? i was able to find axles for every version but the 05-06 rear
    Quote Originally Posted by DBRODS View Post
    412 Motorsports
    Round Rock, TX
    Spline is still 33 and they can make whatever length you need..
