5.3L build and Truck its going in :)
Hey guys, new to the forums. Here is my 5.3L build that will be going in my Black 1992 C1500. Things Done: Chromoly rings, SDPC Z+221 Cam ( 221/226 .565/.560 114 LSA ), ZO6 valve springs, double chain billet timing set ( had to clearance the front cover ). All new cam bearings, rod bearings, main bearings, seals, gaskets, o-rings, freeze plugs. Honed cylinder walls, machined heads. Just finished the grinding, cutting and sanding on the top of the stock manifold, going to be painting it a flat black. A set of red aluminium fuel rails and steel braided cross over ready for that. Red MSD plug wires. Ordering starter, alternator, power steering pump and a set of Schoenfeld LT Headers and will be having them cermaic coated. Then just wiring harness / ECM, flexplate spacer and motor mount adapters. YAY!
- You may not post replies
- You may not edit your posts
