? about a BBK throttle body
i just got a new BBK 80mm the air filter side has the clean cut bore leading to the butterfly valve and the rest of the opening is the cast alluminum rough surface should i dremel it and sand and polish it to clean up the bore? would it make any difference or would it be a waste of time?
Yeah, why not. Go ahead and smooth it out. Wouldn't hurt anything...
- You may not post replies
- You may not edit your posts
