Hi guys, were working on a 6.0 LQ9 and we had one of our part time workers pull the motor apart, were getting ready to re-assemble it but the problem is the worker forgot what order the main bearing caps were. They are numbered 1 through 5, right now we have 4 of the 5 numbers lined up, if we try to line up the main bearing with the number 5 it creates a big gap between the cap and the block, also there the notches where the main bearings go do not line up. Another problem were having is that on numbers 2-4 the notches all don't line up. Every motor I have built the notches have always lined up, but if we switch the numbers 2-4 around to make the notches line up it creates more gaps. I have posted pictures below.
On the next picture you can see the notchs lined up on the number 1 cap
and here is the number 2 cap where the notch isn't lined up
Any help would be appreciated, thanks!
