Thread: So Mr. Nelson....
    May 2004
    Hi, you made a post on LS1 in reply to my "CPS relearn" blah blah blah.
    Now, this wasn't from one of your tunes, but it would be great if you could share some more expertise and tell me if the CPS out of range (something like that) code is losing me power and fuel economy? It does smell a little rich but then again I've got no cats.
    Thanks!
    -Derek
    99 White Regular Cab Sportside 5.3L
    Belltech 2/4 Drop, 01 LS6 Cam and Springs, Pacesetter Headers, K&N FIPK, Cats Removed, Dynomax Ultraflow dumped before axle, K&N FIPK, Corvette Servo, Reflexxions Cowl Hood, APC Rollpan, TekStyle Tonneau, Clear Corner Lights, Polk Audio Boxed 6x9s
    Hey Derek,
    According to the articles and docs I have, it's not supposed to, but I have had one customer say his idle was off and after the relearn he noticed an improvement. If I didn't have the docs in front of me, I'd say it does affect it. It has to do with position of the crank, and that seems vital to me.
    If you can find someone with a Genisys, TechII or similar scanner, they can easily perform the special test.
    I drove my truck for two years before performaning the relearn and I didn't notice any difference. I know, two years hahahah,
    The smell is from having no cats, you're proably not ever going to get rid of that smell, it's like adding a healthy cam to your engine, you're just gonna smell a little more gas.
    good luck,
    allen
    Dec 2003
    Originally posted by farmtruc@Oct 25 2004, 01:15 AM
    Hey Derek,
    good luck,
    allen
    So, Allen, I smell alittle bit after the new cam and no cats, so I'm most likely not running a little rich. It isn't bad at all, so I'm glad I saw this post. It does, however, seem to be getting a little worse on surging coming to a stop sign or light and going into reverse. I really hope the retune gets it straight, because I'm extremely pleased with the tune and the swap as a whole. It isn't far from perfect!!! I know a plug change will probably help things too, since I recently found out my expensive ass plugs are total crap. I'm swapping to the NGK TR55s Friday, so that can't do anything but help. Thanks again.
    Jeremy
    http://images.cardomain.com/member_i...58_26_full.jpg
    1999 Silverado Stepside
    Performance Mods- LQ4 6.0L,TR224 cam,worked heads,Comp918s,Thorley Headers,Nelson Tune,Magnaflow mufflers,Magnaflow xpipe,electric cutouts,TCFuddle 3800 stall,TeamTripp tranny,3.73gears,airaid mit,poweraid tb spacer,LT1 fans,permacool cooler,Nelson harness NX happy gas
    Fast enough to crack your mustang!!!
    Best 1/8th et- 7.40@93mph with a 1.92 60ft(spinning)
    Best 1/4 et- Find out yourself!
    Jun 2003
    hey slow i hope that thing gets worked out for you. im sure allen will hit it this time. and hurry up and get them 55's in there.
    oh yay when i removed my cats it smells rich also. but it is the smell of hp.
    formerly 02denali 12.79@107
