Is there any difference between a LS1 engine from Corvette and a Camaro ??
The Camaro "only" got 305 hp, but is it throttled down with the controlbox?
I believe the z28 is rated at 305 and is not an ls1, the ss is rated at 320. These are underrated #s from gm. As far as the difference between the vette and the camaro I think are the heads, cam, and maybe the intake. There should be some other things but I really dont know what they are.
s&p headers, custom radiator with e-fans,91 sub front end with billet grill and bowtie,autometer gauges, red and grey tweed interior, dual 2.5" flowmaster super 40, Dmh cut outs, 5"-7" drop,air shocks, 20" Intro twisted vistas, gaylords bed cover
Both F-Body and Corvette's have LS1's. The difference is the pulley configuration and camshafts. Some have the same heads, same blocks, different exhaust manifolds and compression ratios. Some 2001-2002 F-bodies came with LS6 intakes and some had LS6 blocks like my 02 WS6 Trans Am. The compression ratios and cam sizes is where the HP differences come from.
Here's some great info from Smokemup. It needs to be updated though.
LS1 Camshaft Specifications1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration
0.496" / 0.496" int/exh lift
116 LSA 2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift
116 LSA 2001 LS6 cam
207/217 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
116 LSA 2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA GMPP Hot Cam
218/227 int/exh @ 0.05" duration
112 LSA GMPP ASA Cam
226/236 int/exh @ 0.05" duration
110 LSA 6.0 LQ9
207/196 int/exh @ 0.05" duration
0.479" / 0.467" int/exh lift
116 LSA 5.3 LM7
190/191 int/exh @ 0.05" duration
0.466" / 0.457" int/exh lift
114 LSA
Stock 5.3 HeadsChamber61.15 cc0.1000.2000.3000.4000.5000.5500.600Intake200 cc63128179210218221226Exhaust70 cc5493121145163168174Valve Diameter Intake1.89"Valve Diameter Exhaust1.55"Part Number12559852
12561706
Stock 6.0 HeadsChamber71.0 cc0.1000.2000.3000.4000.5000.5500.600Intake???66142196228236238240Exhaust???59104137155167173177Valve Diameter Intake2.00"Valve Diameter Exhaust1.55"
Stock LS1 HeadsChamber66.67 cc0.1000.2000.3000.4000.5000.5500.600Intake200 cc67122178215219223227Exhaust70 cc5297133156170176180Valve Diameter Intake2.00"Valve Diameter Exhaust1.55"Part Number12559853 (1997-98)
12559853 (1999-00)
12564241 (2001-03)
Stock LS6 HeadsChamber64.45 cc0.1000.2000.3000.4000.5000.5500.600Intake210 cc62126184224251256257Exhaust75 cc57108143163176180183Valve Diameter Intake2.00"Valve Diameter Exhaust1.55"Part Number12564243 (2001 +) LS6 valves are 0.6mm or 0.023622" longer, hollow stem intake, and hollow stem sodium filled exhaust valves.
LS6: intake = 73 grams, exhaust = 65 grams
LS1: intake = 101 grams, exhaust = 94 grams.
Intake ManifoldsPart #EnginePlenum VolumeRunner VolumeRunner Length125563331997-2000 LS15.06 L0.536 L262 mm125611822001-2002 LS1/65.19 L0.541 L262 mm125735722002+ LS1/65.19 L0.541 L262 mm??LQ44.0L 0.541 L263 mm
Throttle Body Information:
A 98-99 TB has a brown spring on it and a smaller throttle cam, GM Part# 17113390.
A 2000-2002 TB has a blue spring on it and it has the biggest throttle cam, GM Part# 17113647.
A Truck TB has a orange spring on it and a cam that is close to the 98-99 F-body ones but it's not an exact fit.
In short when looking for swapping throttle bodies from one car to another check the color of the spring.
General Specifications Displacement 5.7L (5665cc, 346ci) Gross Horsepower 310 @ 5200 RPM, 320 @ 5800 RPM Bore/Stroke 3.90/3.62 Gross Torque 340 @ 4000 RPM, 330 @ 4400 RPM Compression Ratio
10.1:1 Maximum RPM
6200 Firing Order
1-8-7-2-6-5-4-3 Out of crate weight.
Approximately 390 lbs. Spark Plug
ACDelco 12
ACDelco 41-985 Spark Plug Gap
.060”, 1.524 mm
Block Specifications Block Material
319-T5 Aluminum Block Description
90° V, Deep skirt with cast-in iron sleeves. Bore Spacing
4.40” Deck Height
9.24” Main Bearings
5 Thurst Bearing
Center Bulkhead Bearing Caps
4 vertical bolts, 2 cross bolts
Cylinder Head Specifications Material
356-T6 Aluminum Description
Cross flow, wedge combustion chamber. Ports
Symmetrical, intake and exhaust Chamber Volume
67.3 cc Head Gasket
0.052” compressed
Crankshaft Specifications Material
Cast Nodular Iron Features
Undercut and rolled fillets. Crank Pin Diameter
2.10” Main Bearing Diameter
2.56”
Piston Specifications Material
Cast Aluminum Description
Strutless, flat top. Compression Ht.
1.34” Weight
15.5 oz.
Induction System Manifold
One-piece composite. Throttle Body
75.0 mm bore dia.
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
Thanks A LOT
The 2002 LS6 came you have listed to, whats the rpm range its good for? I see a lot of people recommend that cam for turbos, as well as the 220/.581 cam.
In 2001 and 2002 all ls1 f-bodys came with the ls6 intake and I'd give anything to have mine back.
David,
2003 GMC Sierra Denali, LQ4, AWD, AWS, 4.10, Wheatley 93 tune, LT headers, GMPP CAI, BBK 80mm TB, MSD wires, E3 plugs, 160* T-stat, Flowmonster DI/DO, cutouts. Working on 4.8 heads, just purchased Comp 228R cam, 918 Springs, TI retainers, 7.4 hardend pushrods,
