Results 1 to 8 of 8
Thread: ?Corvette servo= Retune
    Okeechobee, Fl
    Question ?Corvette servo= Retune
    When I got my tune I told nelson I wanted hard shifts and now I'm wanting even harder shifts. I saw that I can get them for $14 at OPT. The ? is will it put to much strain on my tranny if I get them? But I'm not wanting to hassle with sending PCM to get retuned then having to fight with stealership to get crank relearn!!!!
    49 Ford F1
    S.A. Texas
    I am told that the servos help extend the life of the tranny
    Okeechobee, Fl
    That's what I thought, but because my shiftpressure was bumped up in my PCM if it would be too much pressure with the servos?
    49 Ford F1
    ff_jeff Guest
    youll need a retune. It will shift too hard I think
    [quote=06 4.8;178864]When I ... sending PCM quote]
    If you like hard shifts, you might want to go ahead and install the servo.
    If the truck isn't shifting hard enough right now, then it'll shift pretty good when the servo is in.
    Everyone says to put the stock line pressure back in the pcm, but in some cases, it's ok to raise the shift pressure to get the desired result.
    For example, I have a FLT 5 80e in my truck, I had to raise line pressure to my liking.
    If you put the servo in and it's way too hard, then drive it easy and give us a call to get a retune out to you.
    allen
    Okeechobee, Fl
    Well my dad has a fully built 700r4 and it snaps my neck back and it's almost instawood!!LOL!! Another ? is will it eliminate alittle bit of the slip from 1-2 at WOT?
    49 Ford F1
    Quote Originally Posted by 06 4.8 View Post
    It will def. take that slip out. Thats where they talk about extending the life.
    Okeechobee, Fl
    QUOTE It will def. take that slip out. Thats where they talk about extending the life. QUOTE. SWEEEEEET I'm going to order them tomorrow!
    49 Ford F1
