If you wanted to do some custom headers you can get flanges for around 50-60$ this was the route I was going to go but the engine I bought came out of an obs project and came with a set of the schonfield headers already. Good luck with the swap that will be soooo sick!
Damn, that looks a lot nicer than my CCLB.
Did you ever find anything for headers?
I just got done doing an intake gasket and the updated electronic injectors in my CC, and it made me realize LS motors are much easier to work on. I'm addicted and want to start motor swapping everything now.
I found 1 7/8 from southern performance but i haven't found any install pictures for clearance , reason im wanting 1 7/8 is that i migth consider a s/c upgrade
ok guys , i finally pull the plug on headers ended up geting schoenfeld with coating, i also ordered dynatech high flow cats and mounting adapter plates .,,,,
know i decicded im going to go a different route im going to end up getting an lsx376 .I will be getting an ls3 intake and maybe consider a s/c down the road. sa for know i need some assistance on deciding which oil pan to order, and ls3 coil packs either stock or msd
ok guys i wanted to give yall an update . im about ready to start the swap Im going to end up using an lsx376 now i just odered the ls3 intake for it does any of u know what part number trotle body comes with, it says is an 2009 corvette intake with all the parts.
im looking to see if the trottle will work with the dwp from the harness i got which is the one used on the ls3erod .
the setup will be more like the erod with an lsxblock
If the intakes of a 06+ vette or 2010+ camaro then itll have 90mm dbw.
EBay for ls3/7 TB. They're about 150$.
the intake is gm 12610434
its says its 2009 production setup.
yeah it comes with th 90mm trottle i just dont have the part number to do more research , im looking to see if it will work pedal 10379038or if i need a different one
Hello,
Been a long time since last been on here,
Wanted to check in and give some update. I’ve had the truck parked for the last year and half. I have finally put it back together from redoing the suspension and brakes. I am now planning on doing either a turbo install or a supercharger.
I ended ip using the holley R4 a/c bracket on the initial swap and don’t yet know if this works with magnuson Sc.
