Bad fuel pump?
Well with the motor off and ignition on, i get 50 psi but it quickly drops to 5 psi. So its makes the truck hard to start, but with the truck running i get a constant 54 psi. i just got a FPR warrantied just incase but that wasn't that. Thoughts, bad fuel pump or what.
Fuel pump is on its way out. That, or you have a leak somewhere which is bleeding off after the pump primes.
Were should I look for leaks? I havent seen anything noticeable.
Check the hose that goes from the pump to the top of bucket assembly for cracks.
if its the pump, should i go stock or what.
Just as well off going with a Walbro.
I thought i read somewhere that they were having problems and failing. And witch one should i be looking at.
As long as it is genuine Walbro (like Nelson or TSP sells) it will be fine.
i dont see it on nelsons site, but i do on texas speed. Does a 130 bucks sounds right. Sounds a little cheap to me.
That is the correct price. Call Nelson if you prefer to order through them. They do have them.
