I am trying to wire my autometer speedo but do not know which wire it is on Allens harness. Can anyone chime in and let me know which one it is? Thanks in advance.
The one with the white tag on it that says "SPEEDO" :laugh:
Red... what happens if that tag no longer exists?????????????????
That's when you fall back on the PCM wiring diagram. :doh:
Go here to check PCM pinouts
Ok I have that so far but the gauge does not work yet. There is an output coming from the gauge, do you know where that goes?
Do you have the sensor connected on the transmission tailshaft?
Yeah, is the output from the gauge supposed to be tied into the vss?
From what I have read it is only hooked to the VSS if you are not using a PCM. The PCM needs the input from the VSS for controlling the transmission. If you hooked it up to the VSS you would cut the opposite wire and ground it to the frame.
What model number speedometer did you buy?
From summit racing I believe it is atm 4489. It is the 5" electrical
I think Sprayed99 has that type of speedometer. If he checks in here maybe he'll have an answer for you. I can't remember if 1BADC10 has that style speedometer or not.
Cool. Hope they see it and provide some info
Oh, man... Sorry for the late replies.
I have the 5" Autometer gauge with black face & red needle. Street Rod Designer Black (#1489). I hook my signal lead from the VSS output on from the PCM to my gauge. Then, there's the obvious switched power & ground. PM me if you have specific questions. I'll do my best to help.
