Quote:
OK I have in front of me Volume 3 of the Helms manual for my 2004 Avalanche...
The IPC has several feeds. It recieves 12V hot all times at P100 (Plug) on Pin B11 color is orange.
Ground is On pin B12 which is Blk/Wht in color
Ignition circuit is Pin B9 through plug P100 and color is Pink.
It would appear all indicators are led diode in parallel off of the class 2 data bus module (sorry this is a block diagram)
All lamps show a common Ignition pwr circuit in parallel and independent ground circuits controlled by the class 2 data module. There are no wire colors assigned to either pwr or grnd circuits so I would assume all of this is by printed circuit board. All gauges show the similar pwr and ground scenario back to the Class 2 module
I can send these sheets from work tomorrow in any form you need. PM me to let me know whether to fax, scan and post, or scan and email... Whatever you preferr....
Hope this helps.... BTW.. I have several silver conductive pens left over from my computer overclocking/mod days if you run out.... :)
Im still OCed but not running my water cooling setup anymore...LOL I have a box full of overclocking shit around here! I guess email would be the easiest way for me to access it.Thank you very much for the info.I will try to get the led's soldered on tonite or tommorrow :thumb:
