Quote:
Originally posted by Sleeper@Oct 14 2003, 11:38 PM
[deep breath]
tranny will bolt up, but id go for a rebuild if you stick with it. advantage of a t56...put yourself in full control of everybit of your powerband in an instant at your control. for the bugdet you mentioned you might consider a auto/motor with 60-70k miles...thatll put the price around 3000-3200 and leave room for other stuff that needs $. s&p makes motor mount plates, GMCWANTSLS1 has some i believe(~$40). Radiator should be a good 2-core to help cool a bigger ci motor now. PCM will need a VATS bypass(if no painless harness) at least, gear ratio and tire size also need to be programmed.... and harness(harness you can sell imo and go with painless, allen will tell you you can splice it into the existing harness, he did it). fuel pump inst a necessity, but recomended. You'll need to hold 60-65psi continous for the LS1, so you may need a FPR. A/c....vette accesories or trucks accessories can hep you out there, or Allen(farmtruc) knows a guy making his brackets to relocate em up top on the f-bod motors as well. as for best engine...id say newer the better, seems like GM improved things every year....id say 01-02 are better(some LS6 blocks and LS6 intakes) allen says he gets 24-26mpg with his and thats with his 2600 stall, now hes got a 3200 and claims to retain the same i think, but he can clear that up later. for the driveshaft...id say upgrade, allen threw his, and with the motor not sittin in the exact same place, it may set your d/s anle off just a hair enough to throw it, especially with the plates you will nee to shorten just a bit i believe(~62" for a reg cab)
hth there will be more to chime in...in the meantime feel free to check out some of the swap tips and reference pages, allen just go em up and running the other day...lots of good info!
whew [exhale]
Stupid n00b question time!!!!!
