Hi,
I've been reading the board for a while and have learned a lot, but I have a few questions about the swap I'm planning. I have a 1993 GMC Yukon 2dr 4x4 with a 350 TBI, 4l60e, NP241 transfer case and a 10 bolt rear end. I am in the process of installing a 6 inch lift kit and plan on installing 35 inch tires. I plan on using a harness and tune from farmtruc, aluminum radiator with electric fans, S&P ac compressor setup and not sure about motor mounts. Am I missing anything??
The main questions I have are if I install a LS1 and 4l60e from a camaro/firebird will my transfer case and adapter bolt to the new transmission? Will the transfer case fit in the stock location? Which would be the best year vehicle to get the donor LS1/4l60e from?
Thanks,
Tony
