I have a 03 chevy silverado with the 4.8 and sometimes it leaks coolant and some times it doesnt i have been looking all around the motor for leaks i cant see any signs of wet spots any help with be great thanks
heater core lines
you might want to put a pressure tester on the cooling system, the water pump are known to leak all the time.
I had a similar problem, turned out to be seeping out the weep hold on the water pump, almost couldn't find it it was so little of a leak
Now I know where to really start looking. Past couple years mine has been leaking coolant but its not constant. Had the problem with the first real cold day went to heat up the truck and it wouldn't heat up again unless I revved the motor up from idle.
cracked heads, I have this problem as we speak on an 04 sierra 5.3
pull a valve cover, if its all yellow under it......sell your truck :)
Water pump most likely. Ive had 2-3 on previous vehicles where I could only smell the sweet syrup smell but never saw any puddles. It usually leaks from the weep hole at the back like stated above.
on this trucks the water pump seals go out and the house coupler at the firewall cracks as well. my bet is the waterpump to engine seals have cracked
I have the Castech problem, goin to a dealer to c if theres a chance they will fess up with some new heads
Lol.. easy! HIGHLY doubt its internal if its not been ran hot. Like was said its probably heater hose connections,water pump,radiator, but dont rule out freeze plugs or heater core..get you a pressure tester,mirror, and a good flashlight and park it on some clean concrete! Look over it SLOWLY
