Does anyone have any nitrous jets they could spare for a small fee? I need an .063 and an .073. I need em by Friday the 4th.
Which brand?
Nos.
I found a NX 73 on eBay for 5 bucks. Will it not work with NOS?
I have some nos brand jets ill never use again lemme check and see if I got what you need itll be tomorrow before I know pm your address and if I got em ill send em out.
Idk if they're interchangable but I think the shaft is shorter on nos jets.
You could make our jets fit but you would need to drill out the fitting that the jet goes in, because our jets are fatter at the base. If you need to drill it out you would need to use a .187 drill bit.
Trey
Would the NOS jets still work in the fitting after drilling it out?
Yes they would work fine but they would be a little loose without the line attached.
Trey
That is very helpful thank you.
No problem
