So has anybody ever run these on a NBS? What all is needed to make them work?
Nobody?
Front or rear? Either way, just some caliper massaging.
I just looked at them and I can only find them with 4" BS which wouldnt work. They will stick out like 2" past the side of the truck :( I need a 15x10 6 lug with 6-6.5" BS for cheap and nobody makes them!!
If u get anywhere on this lmk lol. I'm on a stock wheel too. Iv thought about having them widened but lots of $
Someone has to know. looking for a set as well.
Try diamond wheels. I haven't looked there but I believe they make them anyway.
They make them!! Thanks kyhunter!! Ill be calling them tomorrow! Ok guys help me out, I'm going to do a drum conversion to run 15s if when I get the wheels I decide too much grinding is required. Do I need to run drum axles or will my disc axles work? Also I'm going to put some drag radials on the 15s for the street. But I have a predicament. My current drag setup is 28x10x16 Hoosiers on narrow 7" stock wheels. Do I also buy some 16x10s for those to get more contact patch which I really need or do I get another set of 15x10s and sell the current drag setup and buy 15" slicks?? My slicks prolly have around 20 passes on them at most.
I dont see any reason why not to stay with the 16s. Unless theres a size they dont make in 16 inch. If your already running 16s on disc then id keep it that way.
The tire options for 15s is crazy compared to 16s. That's my main reason for wanting to swap to 15s. The tires I've been getting, my 295/50/16 Goodrich radial t/a is no longer available. I found a few sets of 325/60/15 that would be sick
Get em on there n post some pics lol.
will do, but does anyone know if my stock disc axles will work with drum brakes?
