Anyone care to post up a pic of the adapter installed, also I cant find a adapter in brass anywhere,, where can I buy brass,, I don't want the chrome
i went a different route on my coolant temp sensor. it's a 3 pin connector with a mini harness. this way to only need the one sensor.
http://i22.photobucket.com/albums/b3...1/DSC_0947.jpg
I am confused, thought I had all this worked out in my mind, my nelson harness will require a temp sensor and I will also need one for my gauge in the dash correct??
yes, the Nelson harness will plug into the 2 pin connector. the green wire will run to your gauge.
Or I can simply plug the nelson harness into the LS temp sensor and drill and tap my water pump for the temp sensor off my old engine and use it for my stock gauge right?
I drilled and taped for a mech temp gauge
http://i136.photobucket.com/albums/q...t/6a78c926.jpg
three pin is okay but you better get an infrared or some kind of temp gauge to double check the reading because it will be way off. Mechanical is a smart way to do it but you lose the dash readout. If you have an idiot light like my 92 had then the mechanical gauge is 'da bom!
So I need to plug in the nelson harness into my new motor and drill and tap or place the old sensor somewhere in the coolant system correct?
My passenger head had a port for a temp sensor blocked off wuth a plug. Driver side is for pcm.
Thanks for that info Redheartbeat, I checked mine with infrared temp gauge and it was 40* off, dash gauge showed 120 and infrared showed 195, I am using the 3 wire temp sensor and only tied into the 3rd wire, ground. I still have 2 wire sensor for the computer.
My 3 wire temp sensor is only off by 10*.I didn't like having the truck temp sensor in the back of the passenger side head because it was right in the way of the spark plug wire.
I got this 3wire sensor duralast #tu178, and pigtail but its too big for my cyl head. Would I still need the s&p adapter? Or should I just run the stock 2wire and get the $60 adapter Ray got?
Product Information
Product Name Part No. Quantity Item Price Total Price
Coolant Temp Sensor & Pigtail for 82-92 Camaro/Firebird Gauge LSX Conversion FST18527/12551708 1 $45.00 $45.00
Subtotal: $45.00
Shipping: $5.00
Tax: $0.00
Order Total: $50.00
Here is the 3 wire coolant temp sensor i got from Hawks 3rd Generation.I put in place of computer sensor in drivers side head and left passenger head plugged.
