I had 323 possy and swapped to a 342 1tf rear end. Next week i am Ordering 430's and a locker. Are they really worth the money will i notice much change. a few people i have talked to said they will make my truck seem slower?
Thanks man. i was just thinking with all the people that told me that to get something else but i think i will be happy with the gears and locker..
Touche'
Wow someone deleted a good reply.
yea i dont think of mph as fast. its not how fast your going to me its how fast you get there. my problems is geting up and going right now. i usually have to play catch up so now if i get gears i think i should be better getting out and up to speed faster. :) thanks. heres my problem http://www.youtube.com/watch?v=8kWV_mAVLdU http://www.youtube.com/watch?v=hJtQeufA07o
Back when I was stock, I went from 323s to 410s, it felt like I gained more with them then a cam :lol:
Awesome im going from 342 to 430s then i hope the same for me thanks g
What size tire are you running?
Gears are one of the most important parts of every build. I have rcsb with 4.8 265 70 r20 went from 342's to 410's. I was very pleased with the results. If I ever have to do it again I'm going 456's
so are you saying i should go ahead and go with 456 instead of 411?
You'll probably be happy with anything from 410 - 456 but I wish I would of went with 456 because of the lack of torque my 4.8 has and the rpm range of the cam I just bought.
456 it is i guess
on a 31.5 inch tire i gained .4 tenths going from 3.23s to 4.10s, 60ft stayed the same bc of traction issues so thats a great gain!
Best mod other than a tune! Check out 4.30s, that's what I'm going with. I'm on 33s.
gears is the best difference your going to feel besides nitrous or forced induction.....gears are worth it
Don't fear the gear. I've had 4.10s and want 4.56s.
What does your run rpm on the highway? I was talking to chris at LSX about that today and they couldnt recal.
2500 at 70 on a 30'' tire 22s)
This should help select a gear. It shows the RPM your engine would be at in 3rd (1:1) at 65mph. Just multiply the RPM for the tire and gear combo by 0.696 (OD ratio)
http://www.omix-ada.com/images/gear-ratio-chart.gif
