It all started back in March of 2006. I bought my first NEW vehicle - a 2006 chevy silverado. About a year later, the modding began and I'm still not finished.
The garage/Man cave
http://www.ls1truck.com/forums/attac...3&d=1324539015
The truck/money pit
http://www.ls1truck.com/forums/attac...2&d=1324538956
The Current Engine/gasoline consumer
http://www.ls1truck.com/forums/attac...1&d=1324538896
The performance on 8psi........for now
http://www.ls1truck.com/forums/attac...5&d=1324591709
The bed
http://www.ls1truck.com/forums/attac...3&d=1324578668
Around July of 2011, I finally finished building the 6.0L and it was ready to drop in. I ripped out the 4.8L (still ran great with 60K on the odometer) and the rear mounted garrett T-04 turbo, cleaned everything up, and stuffed in the 6.0L with a front mounted MP T-76.
The old 4.8L
http://www.ls1truck.com/forums/attac...7&d=1324541786
The new 6.0L......a little used actually but still in awesome shape
AND
The Mods:
~Comp 220/222 580/580 114+2 cam
~Patriot 317 heads with all the goodies and hardened pushrods
~ARP rod and head bolts
~SLP double roller timing set
~Scorpion 1.7:1 roller rockers
~LS7 lifters
~LS9 head gaskets
~Methanol (Methyl alcohol) system
~KB Front mount hot pipes
~Master power T-76 - .72/.96
~Built 4L60 and a tru-trac in the rear end
Pump gas......No nitrous
http://www.ls1truck.com/forums/attac...8&d=1324573867
http://www.ls1truck.com/forums/attac...3&d=1324574357
http://www.ls1truck.com/forums/attac...1&d=1324574314
http://www.ls1truck.com/forums/attac...0&d=1324574254
http://www.ls1truck.com/forums/attac...7&d=1324573803
http://www.ls1truck.com/forums/attac...2&d=1324574339
http://www.ls1truck.com/forums/attac...6&d=1324574424
I thought this was a clever way to check the valvetrain. I soaked the lifters in oil since they were brand new and are hydraulic roller lifters, then installed them. I slapped the heads on, painted the roller tip with a sharpie and rolled the engine over to see exactly where the roller tip would contact on the valve stem. Looked good to me!
http://www.ls1truck.com/forums/attac...5&d=1324574404
http://www.ls1truck.com/forums/attac...7&d=1324575527
http://www.ls1truck.com/forums/attac...8&d=1324575555
http://www.ls1truck.com/forums/attac...3&d=1324749871
http://www.ls1truck.com/forums/attac...4&d=1324574383
......and the swap:
That thing from the movie "Super 8" stole my engine as well. HA!
http://www.ls1truck.com/forums/attac...0&d=1324576596
http://www.ls1truck.com/forums/attac...9&d=1324576532
In ya go:
http://www.ls1truck.com/forums/attac...6&d=1324541763
http://www.ls1truck.com/forums/attac...5&d=1324541728
now for the turbo.......
http://www.ls1truck.com/forums/attac...3&d=1324541676
http://www.ls1truck.com/forums/attac...8&d=1324541838
And the finished product!
