Is it worth the money to buy a new throttle body, or should I just port and polish mine?
Is it hard to P&P a throttle body, and will it make any difference?
Well worth it, since its cheap and helps throttle response. This with a CAI helps smooth out the flow of air. Same as done with mandrel bent piping on the exhaust side. So its not to help pull in more air, but to help reduce turbulence.
p&p is a nice easy upgrade that takes about a day depending on whats done.
I wouldn't do it yourself if you haven't done it before...
http://www.s2performance.net/gmtrucks.html
:thumb:
Not yet, but when I spoke to my tuner about going to an 85mm aftermarket or having the stock P&P'd he said not to waste the money on a larger TB and just have it P&P'd.
im wanting to P&P my TB. ive never done it before... what exactly should i do? find someone in my area that can or buy one from the site listed above?
What size throttle body does a 2004 Chevy with the 5.3L LM7 come with?
port and polish! im badass at it
