http://i786.photobucket.com/albums/y...rucklights.jpg
http://i786.photobucket.com/albums/y...okedlights.jpg
http://i786.photobucket.com/albums/y...derthehood.jpg
http://i786.photobucket.com/albums/y...kinthesnow.jpg
Lets see some more pics looks good.
nice, need more pics
http://i786.photobucket.com/albums/y...truck/tuck.jpg
older picture with my old 20's
kk ill see what i can do in the morning
added new pics up top^^^^^
nice truck! just dont like that sticker on the back glass. seems like every arizona truck has them.
here's a old picture when i had my 20's
Stainless box we made for my future crowell hood
http://i786.photobucket.com/albums/y...boxintruck.jpg
Resurved for pictures
Reserved for pictures
Saved for pics
Beautiful truck. Someday I'll own one.
thanks man, ya its been a long porject im currently doing a turbo install on it. i dont have acess to post pictures so ill have to once the internet people come and hook up the new internet.
don't like those chrome rims but everything else looks nice
haha, ya i ditched the 20's they were super heavy too. and thanks, ya im currently looking at adding to the truck
76mm turbo.
kb racing 3.5in hot pipe kit,
80lb injectors
walbro 400 fuel pump/ hot wire kit
devil'sown stage 2 meth kit
comp cam's rocker upgrade
brian tooley's duel spring kit.
its a slow process but should be fun once its done. so far got the pump in, all the gauges ran, the rckers done and the inner cooler an tranny cooler in. started the springs last night.
time for alittle up date.....
4l80e, installed with a cir-d 2b multidisk, brian tooley spring kit, comp rocker up-grades, 80lb injectors, walbro 400 fuel pump, kb racing turbo kit with a 76mm turbo 1.15 A/R
had to relocate the tranny cooler so the inner cooler would fit
http://i786.photobucket.com/albums/y...ps7d7eb7a0.jpg
Quick shot of the new springs...
http://i786.photobucket.com/albums/y...ps3828d497.jpg
http://i786.photobucket.com/albums/y...psbc18f3e8.jpg
Tbss injectors vs the new 80's
http://i786.photobucket.com/albums/y...psf241ec99.jpg
Finally got the turbo in
http://i786.photobucket.com/albums/y...pse7103e42.jpg
http://i786.photobucket.com/albums/y...ps45280d9d.jpg
and the cold side
http://i786.photobucket.com/albums/y...ps7def346b.jpg
http://i786.photobucket.com/albums/y...ps65d4a0d8.jpg
As she sits today...
http://i786.photobucket.com/albums/y...psbf906c58.jpg
Looking good boss
haha, thanks man. its been a rough strech in this 115 heat! but should have it buttoned up enought this week to get it outa the gurage till i get back from my 3 week training. i still have to get the DP and exhaust done, install the new wiring harness for the fuel pump, then get the MAF sensor hooked up and in " just till i can get a SD tune" then retune and hook up vaccume lines. think thats about it
well i took it outa garage before i take off for Georgia. sprayed er down and took a few pics. wont be able to finish it till i get back the end of the month. did find out i got a fuel leak from 2 of the drivers side injectors should be to hard to fix just gotta pull it all back off.
http://i786.photobucket.com/albums/y...psc0ce62e2.jpg
http://i786.photobucket.com/albums/y...ps9d8579a3.jpg
HELL YES! Looking good! Your on the right track now!
haha thanks man. ya it will be another month or so tho im leaving for 3 weeks for training so it will have to sit till then. hopefully the injectors are the only issue i run into ;)
i gotta still do the fuel pump harness, then get the exhaust done. hook up the vaccume lines then do the oil feed and drain lines, and fix the injector is there any other things i should check before i try and crank it up?
finally back home, time to get the truck done! got the rest of the parts ordered including the tune. i ended up ording new o-rings for the injectors hope it helps. im still trying to decide weather or not to do the drain line with the pan on or off. gunna try and get the fuel harness done in the next few days aswell. biggest thing is figuring out the exhaust
Do you like loud exhaust? Id tun that bitch with no muffler lol.
haha i dont the people around me already hate me! but idc :) my plan so far is a stock 3.5 in d-max exhaust i bought a full one for $75 of a ext cab. should be close, my main issue is getting the 4" turbo exhaust to mate with the 3.5 DP. i got a flange that goes from 4-3.5 but i got to get the mesurments and have the flanges welded and such. i plan on running it stright piped for now tho :0
all i got left now is the harness and the oil lines. i think im gunna just try and do it in the timing cover due to the 4x4 crap in the way. and finally found a place to do my exhaust :)
if you have a porta-band, welder and grinder you can order all the bends and tubing and do your own exhaust. Thats what I do. Good job on the progress man
ya my welders gone now :( but im thinking of taking it to a shop and just have them do it. and thanks man, im excited to get er going.
finally got the bed off and the new harness installed. looks pretty good try and post pics later.
looks like it should be ready to go to the exhaust shop by the end of the week. just goota wait tilll my broth inlaw's off so he can help me hual it to the shop :)
pic of the harness hooked up
http://i786.photobucket.com/albums/y...ps9c3edd24.jpg
Truck looks good. How do you like the Brian Tooley spring kit? How good are they? This is the first I ever heard of them.
Brian Tooley is where it's at
havent been able to test them out. there beast looking tho. and a great price i know alot of people run them.
finally alittle update..... shes about ready for the exhaust.... as far as i know the trucks ready to go except for the exhaust. well and needs a bath. hopefully soon tho :)
http://i786.photobucket.com/albums/y...ps97fe2a81.jpg
http://i786.photobucket.com/albums/y...pse3d7b0c4.jpg
http://i786.photobucket.com/albums/y...psba9f85cb.jpg
Truck " should" be done in the next 2 days :) got under it and tweeked the cross over pipe, it wasnt lining up right. finally got it set up and the down pipe and mid pipe look great. all i have to do is get the reduced and 4" flange welded on.... anything i should check before i turn the key? i will add oil to the top of the turbo pre start up. how long do i need to let it run before draining the oil? " i tapped the pan with it on" but i dumped 5 quarts stright threw it right after i tapped it.
