Like the title says, where is the best place to put a turbo oil drain on the oil pan. I was thinking right above the oil level sensor and as high as a I can mount it on the pan. Thoughts?
On the front of the pan under the balancer. As low as you can on the pan. Thats where mine are. Work well... Hope that helps
^^^ Any pics?
http://i915.photobucket.com/albums/a...5/9e4db60f.jpg
Have to look close at the front of the pan
I see them, thanks. Nice LSX by the way
Mine is in the front also, in the same exact spot... had some oil drainage problems with it on the side of the pan. It also causes windage on the crank if its too high in the pan.
http://i23.photobucket.com/albums/b3...e/DSC02643.jpg
http://i23.photobucket.com/albums/b3...e/DSC02602.jpg
i did one on each side , -10 (dont mind the gen3 and gen4 knock sensors )
I ended up having a -12 bung welded on. From what I've heard, this location works well
Attachment 3977
Attachment 3978
