plug wire diffrence
I changed the plugs in my 03 yukon today and one of the wires pulled apart so I stole one off of the 01 5.3 I have that to swap into my thrdgen and its short like iits barely cliped on the coil. Was there a diffrence in length for plug wires for thses years? The wire fit on the 01 motor fine.
99-02 are about an inch shorter. the cars were even shorter then that.
i run 03 wires on everything, like having the extra room to work with.
Well looks like I'm gona head to the parts store in the morning and see if I can pick up a decent set of wires. I can't tell if the plugs fixed my mis or not. At first I thought so then it started idling rough again after 30mins or so but it could be that short plg wire not getting good connection or I didn't get one snapped on good enough. :/
i know at AZ, the wires for the 03's are actually like 20 cheaper then for the 02's. Either should work though. I don't think there's any actual difference in the motors. I actually have 99-02 wires on mine now, they are tight, but fit.
Might be the coil itself. might wanna swap it and see if that helps before buying wires.
Well one ill have to buy some wires regardless since now the motor I'm using for my swap is missing a wire and it bothers me knowing I have a missmatched wire on my yukon lol. Another thing is idk which coil could be at fault. I kept all the plugs and numbered them so I know where they came out ill post pictures of them when I get off work. I didn't know what the firing order for a lsx motor was right off so I numbered them like a old sbc when I pulled each one. The driverside plugs had much more soot than the pass side plugs. I had also started blowing black smoke since this code came up and with it idling over snow the snow would get covered with soot. After I changed the plugs out today it seemed to start easier and idle smoother especialy after I let it warm up then reved the snot outa it a few times and covered the snow in my front yard with soot!
each coil is above each cylinder... the order doesn't really matter :lol:
if you're getting a po300, its random misfire, probably not any particular plug/wire/coil.
If its a Po30# that cylinder has mis. (be it plug/wire/coil). I'd do plugs/wires first. Especially with your mileage. If you still have a light, and it's a specific cylinder try the coil. Could also be an injector, thought kind of unlikely.
check your pcv, if that year still has one. I checked my moms other day, and it was missing the check valve...explains why her truck has been going thru oil between changes. That's only thing I can really think of that would cause "soot" unless you accidentally put diesel in it
Well I've got the papers that showed the code ill look at it when I get off work. I know the coils are for each cyl I labeld each old plug so I knew where it came from so I can look them over.
No I didn't put diesel in it lol but ever since the code you can smell a strong odor of gas from the exhaust and black smoke if you get on it after being easy on it for awhile. Actualy my wife drove it the other day to the store and back 1.5miles each way and said it idled rough when she was leaving the store and I watched when she backed in the drive and it was puffing black smoke the whole time.
Sounds like an o2 sensor crapped the bed.
Found a lose plug wire last night fixed it ans still smokes black under throttle. Codes are p0300 and p0131 pre plug change going again now to get them checked again.
p0171 is system to lean bank 1 i think.check for vacuum leaks or dirty maf
The paper I got said rich condition bank 1 then went on to say the the things it could be. If so it kinda makes sence when I pulled the driverside plugs they were all black and fouled. The pass sisde plugs had a nice light brown.
well i got new plug wires plugs and replaced the driverside upstream 02 sensor! i dont have the new wires on yet but with just the new plugs and replacing the sensor it idles smoother than it ever has since ive owned it. gons try to put the plug wires on while im off work 2weeks for christmas. oh and to ensure i dont have any problems with my cats i just ordered some lts and ory. ;)
here are some pics of everything.
http://i285.photobucket.com/albums/l...01219-1213.jpg
http://i285.photobucket.com/albums/l...01219-1222.jpg
