Ok, I dont have a truck but since this motor comes in the trucks I figure this is the best site to get the info I am after. First off the car is a 92 Z28 that I swapped a LS1 into and have recently pulled the motor to go another route. I have a 4.8L and am going to turbo it but I want to keep it as "sleeper" as possible unlike it was before with the cammed LS1. I was thinking after doing some research looking at a few other 4.8L turbo builds of going with a LS6 cam, 241 heads (since I already have those off my LS1) to drop comp. and my LS6 intake. Then I will build a kit using truck manifolds and my question is which turbo to go with, the car has a fully built RMVB with a brake and will have around a 3K or so stall once its restalled. The car is LIGHT as with the LS1 in it weighed around 2900lb raceweight. The only plans to do anything to the 4.8 is a simple rebuild with rod bolts then later down the road when I get the extra money I will build my LS1 to handle boost or go with a 370 6L. Any help would be greatly appreciated!
Thanks, Nick!
